DJI Air 3S Fly More Combo (DJI RC-N3)
Select Option
1″ CMOS Primary Camera
14 stops of dynamic range, [1] 3.2μm large pixel size, [2] 24mm format equivalent, and 50MP resolution, capture vast landscapes day and night.
70mm Medium Tele Camera
48MP 1/1.3" CMOS sensor, matching the primary camera's video specs and color modes while offering 3x optical zoom for expressive portrait shots.
Dual-Camera 4K/60fps HDR Video
Uses H.265 encoding while supporting 4K/60fps HDR video, 4K/120fps video, [3] and 10-bit D-Log M color mode.
Free Panorama
Capture seamless panoramic shots with Free panorama mode, which stitches together multiple images with a manually selected subject or area.
Nightscape Omnidirectional Obstacle Sensing
Forward-facing LiDAR, downward infrared ToF sensor, and three pairs of vision sensors allow nightscape [4] to detect and avoid obstacles.
Next-Gen Smart RTH With Enhanced Precision
DJI Air 3S can memorize flight paths in well-lit environments [5] for safe returns, even when taking off from areas without satellite signals.
45-Min Flight Time
With up to 45 minutes of flight time [6], Air 3S gives you enough time to scout locations, compose, nail your shots, and do it all over again and again.
20km Video Transmission
DJI O4 video transmission provides 10-bit video transmission at 1080p/60fps for distances up to 20 km, [7] offering smoother live feeds.
DJI Air 3S
DJI RC-N3 Remote Controller
Intelligent Flight Battery
× 3
Battery Charging Hub
ND Filter Set (ND8/32/128)
DJI Shoulder Bag
Spare Propellers (Pair)
× 3
Type-C to Type-C PD Cable
RC Cable (USB-C Connector)
RC Cable (Lightning Connector)
Gimbal Protector
Moments By You
From USD $1,099
From USD $1,099
From USD $2,199
1/1.3″ CMOS 3x Medium Tele Camera
1/2″ CMOS Tele Camera
4K/120fps Slow Motion
4K/100fps Slow Motion
10 km (CE/SRRC/MIC)
10 km (CE/SRRC/MIC)
8 km (CE/SRRC/MIC)
Compared with DJI Air 3, what are the main improvements of DJI Air 3S?
DJI Air 3S has comprehensive improvements in the camera system, vision sensing system, intelligent features, and video transmission system. The main improvements include:
1. DJI Air 3S is equipped with an upgraded 1-inch CMOS primary camera, utilizing a new image-processing platform with a video dynamic range of up to 14 stops*. It supports up to 4K/120fps video recording**. Additionally, its wide-angle and medium tele cameras support the new Free panorama feature, which allows flexible shooting-range selections.
2. DJI Air 3S features new forward-facing LiDAR, supporting nightscape omnidirectional obstacle sensing*** and next-gen Smart RTH. It can actively identify and avoid obstacles, such as buildings along the flight and return paths, ensuring safer urban nightscape photography. It can also memorize flight paths in well-lit conditions, enabling quick takeoffs and safe returns even without satellite signals****.
3. DJI Air 3S adopts the O4 video transmission system, offering more stable signals, stronger anti-interference capabilities, and better image quality.
* 14 stops of dynamic range are achievable for video on Auto mode but not for vertical or slow-motion video.
** 4K/120fps video recording is only supported in Slow Motion mode.
*** This feature is only effective on surfaces with discernible textures and in lighting conditions exceeding 1 lux. Refer to the official DJI website or the product's user manual for details.
**** This feature is only effective on surfaces with discernible textures and in lighting conditions exceeding 10 lux. Refer to the official DJI website or the product's user manual for details.
Does DJI Air 3S support vertical shooting?
Both the wide-angle camera and medium tele camera support vertical shooting (9:16), and a max video resolution is 2.7K/60fps.
Compared with DJI Air 3, what are the improvements in the camera module of DJI Air 3S?
Compared with the camera module of DJI Air 3, DJI Air 3S has the following major improvements:
1. DJI Air 3S features an upgraded 1-inch CMOS primary camera, a new image-processing platform to enhance overall image quality, and provides a video dynamic range of up to 14 stops*.
2. DJI Air 3S supports slow-motion video recording at 1080p/240fps and 4K/120fps**.
3. DJI Air 3S introduces a new Subject Focusing feature, which can quickly and intelligently recognize the subject and maintain continuous and accurate focus.
4. The wide-angle and medium tele cameras of DJI Air 3S support the new Free panorama feature, which allows flexible shooting-range selections.
5. DJI Air 3S employs next-gen intelligent algorithms to significantly improve photo quality.
6. DJI Air 3S increases the video ISO limits: the maximum ISO in normal color mode is raised from 6,400 to 12,800***, and in D-Log M and HLG color modes, the maximum ISO is increased from 1,600 to 3,200.
** Only supported in Slow Motion mode.
*** The maximum ISO for slow-motion video remains at 6,400.
Can I use other USB-C chargers to charge the battery?
Yes. However, to ensure charging efficiency, we recommended using the DJI 65W Portable Charger, DJI 100W USB-C Power Adapter, or other chargers with a power output of 60 watts or above that support the PD protocol.
* All videos and images on this page were shot using DJI Air 3S by professionals in strict compliance with local laws and regulations and have been variously edited in post-production. All videos and images are for reference only. Actual results may vary. Always observe local laws and regulations and ensure the aircraft has obtained relevant certifications and airspace authorizations before flying.
** All data on this page was collected with a production model of DJI Air 3S in a controlled test environment. Actual experience may vary depending on the environment, usage, and firmware version. DJI Air 3S must be activated via the DJI Fly app before use.
*** It is recommended to use the ActiveTrack 360° feature in open environments. Refer to the user manual for unsupported scenarios or those that may potentially interrupt recording. In complex environments with many obstacles, exercise caution when using Auto mode to ensure flight safety and personal safety.
**** All images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
1. 14 stops of dynamic range are achievable for video on Auto mode but not for vertical or slow-motion video.
2. Achieved with QBC (Quad Bayer Coding) techniques that combine four pixels into one. Not supported when shooting 48MP or 50MP photos.
3. 4K/120fps video recording is only supported in Slow Motion mode.
4. Conditions for enabling nightscape omnidirectional obstacle sensing: The drone's front, back, left, right, or top sides are within range of surfaces with discernible textures with illuminance that exceeds 1 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20% (such as walls, trees, or people), also in lighting conditions with illuminance higher than 1 lux. DO NOT fly in severe weather conditions, such as in strong winds (wind speed of 12 m/s or more), snow, rain, lightning, or fog. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects, such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may not work correctly. When GNSS signals are weak, fly the aircraft in well-lit environments: the drone's front, back, left, right, and top sides are within range of surfaces with discernible textures with illuminance that exceeds 10 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20%, also in lighting conditions with illuminance higher than 10 lux. The vision system may not work properly in dim environments. DO NOT fly near areas with magnetic or radio interference. Familiar magnetic or radio interference sources include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Avoid sand entering the aircraft when taking off in desert or beach areas. Fly the aircraft in open areas away from crowds. Buildings, mountains, and trees may block the GNSS signal and affect the onboard compass.
5. Conditions for memorizing flight paths: The drone's front, back, left, right, and top sides are within range of surfaces with discernible textures with illuminance that exceeds 10 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20% (such as walls, trees, or people), also in lighting conditions with illuminance higher than 10 lux. If the drone is taking off from a balcony, ensure the usable space is at least 2 meters by 2 meters, and the height above ground is less than 30 meters to ensure a safe return to home.
6. Measured by DJI Air 3S flying forward at a constant speed of 32.4 kph in a windless environment at sea level, with Obstacle Avoidance Action set to Brake, in photo mode, and from 100% battery level until 0%. Data is for reference only. Always pay attention to reminders in the app during your flight.
