DJI Mavic 3 Classic
  • 4/3 CMOS Hasselblad Camera
    Powerful imaging with true-to-life colors and cleaner night shots. Enjoy 5.1K/50fps or 4K/120fps video recording. [1]
  • O3+ Transmission, 15km Range
    With a transmission distance of up to 15 km, [2] fly farther and more stably with peace of mind and a smooth 1080p/60fps [3] live feed.
  • Unmatched Hasselblad Imaging
    Hasselblad Natural Colour Solution (HNCS) delivers vivid, natural colors, allowing you to capture breathtaking images during any flight.
  • Omnidirectional Sensing
    Mavic 3 Classic continually senses objects in all directions and bypasses them quickly and smoothly [4] for safe, confident flights.
  • 46-Min Extended Flight Time
    Increasing flight time by almost 50% compared to Mavic 2 Pro, Mavic 3 Classic delivers up to 46 minutes in the air for care-free creation. [5]
  • Extensive Accessories
    DJI RC features a built-in 5.5-inch HD display for clear viewing in strong light, professional-grade ND filters for landscape photography, and more, to make results truly stand out.
  • Thrilling Immersive Flight
  • DJI Mavic 3 Classic
    DJI Mavic 3 Classic
  • DJI Mavic 3 Intelligent Flight Battery
  • DJI Mavic 3 Low-Noise Propellers (pair)
    × 3
  • DJI Mavic 3 Classic Storage Cover
Moments By You
DJI Mavic 3 Classic
DJI Mavic 3 Pro
DJI Mavic 3
DJI Mavic 3 Classic (DJI RC-N1)
DJI Mavic 3 Pro (DJI RC)
DJI Mavic 3
DJI Mavic 3 Classic
DJI Mavic 3 Pro
DJI Mavic 3
Flagship
Flagship
Flagship
Flagship Camera Drone With Hasselblad Camera
Dual-Lens Flagship Camera Drone
From USD $1,279
From USD $2,199
From USD $2,049
Image Quality
1/2″ CMOS Tele Camera
1/2-inch CMOS Tele Camera
20 MPPixels
48 MPMax Pixels
20 MPPixels
f/2.8-f/11Adjustable Aperture
5.1K5.1K/50fps
DCI 4K/120fps
5.1KHasselblad Camera: 5.1K/50fps, DCI 4K/120fps
5.1KHasselblad Camera: 5.1K/50fps、DCI 4K/120fps
Tele Camera: 4K/50fps
D-LogNormal/D-Log/HLG
D-LogHasselblad Camera: Hasselblad Natural Colour Solution (HNCS)/D-Log/D-Log M/HLG/Normal
Safety & Flight Performance
895 gWeight
958 gWeight
895 gWeight
46 minsMax Flight Time
43 minsMax Flight Time
Omnidirectional Obstacle Sensing
DJI O3+ 15km,
1080p/60fps Transmission
Max Video Transmission Range: 15 km (FCC)
8 km (CE/SRRC/MIC)
DJI O3+ 15km,
Max Takeoff Altitude
  • Compared to Mavic 2 Pro and DJI Air 2S, what advantages does Mavic 3 Classic have?
  • What are the advantages of Mavic 3 Classic in photo and video shooting?
  • What differentiates Mavic 3 Classic, Mavic 3, and Mavic 3 Cine?
  • Compared with DJI RC-N1, what major upgrades does DJI RC have?
  • Compared with the previous generation, what upgrades does the omnidirectional sensing system on the DJI Mavic 3 Series have?
  • What improvements does ActiveTrack 5.0 have compared with the previous version?
  • What improvements does Advanced RTH have compared with the previous version?
  • What is the difference between normal bypass mode and Nifty mode for APAS 5.0?
  • Is Mavic 3 Classic compatible with the accessories for Mavic 3 and Mavic 2?
  • What precautions should be taken when using DJI Goggles Integra / DJI Goggles 2 with the DJI Mavic Series or DJI Mini Series for the first time?
* Measured with FCC compliance in unobstructed environments free of interference. The actual transmission distance may vary depending on environment, actual use, and firmware version. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted. The above data are the farthest communication distances for one-way, non-return flights under each standard. During your flight, please pay attention to RTH reminder on the app.
1. ActiveTrack is not available at video resolutions higher than 4K or frame rates over 60fps.
2. Measured in an unobstructed environment free of interference. The maximum flight range of 15 km is only achieved with FCC compliance. The above data shows the farthest communication range for one-way, non-return flights under each standard. During your flight, please pay attention to RTH reminders in the DJI Fly app.
3. Tested in an open outdoor environment without interference. Actual resolution may vary depending on the quality of the transmission signal.
4. DO NOT use the aircraft in severe weather conditions, including heavy wind exceeding 12.8 m/s, snow, rain, fog, hail, or lightning. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may be limited. When the GNSS signal is weak, fly the aircraft in environments with good lighting and visibility. Low ambient light may cause the vision system to function abnormally. DO NOT fly near areas with magnetic or radio interference. Common magnetic or radio interference sources include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Be careful when taking off in desert or beach areas to avoid sand entering the aircraft. Fly the aircraft in open areas away from crowds. Buildings, mountains, and trees may block the GNSS signal and affect the onboard compass.
5. Measured by Mavic 3 Classic flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery reached 0%. Data is for reference only. During your flight, please pay attention to RTH reminders in the DJI Fly app.
