DJI O3 Air Unit
Supports shooting 4K/60fps videos with 155° super-wide FOV. Features HD long-distance low-latency video transmission.
Related Products
Integrating DJI's cutting-edge video transmission technology into a lightweight and compact body, the DJI O3 Air Unit features excellent video transmission quality with high definition, low latency, and at long distances. It comes with a 1/1.7-inch sensor, a 155° super-wide FOV, and rich compatibility, providing a powerful video transmission solution for your assembled aircraft.
DJI O3+ Flagship Transmission
Transform your video transmission experience. It supports a max video transmission quality of 1080p/100fps from up to 10 km. [1]
Next-Level Imaging Performance
Equipped with a 1/1.7-inch sensor, the DJI O3 Air Unit can shoot 4K/60fps video [3] with a 155° [2] super-wide FOV, giving you richer image details. It also comes with 20GB built-in storage. D-Cinelike color mode allows you to make detailed color adjustments to your shots. The camera module can be used with the DJI Avata ND Filters Set (ND8/16/32). [4]
Canvas Mode
Canvas Mode lets you customize the OSD information on the screens of DJI Goggles 2 or DJI FPV Goggles V2, and adjust PID parameters.
Compact and Richly Compatible
Packed with richer compatibility in a lightweight body. DJI Goggles 2 and DJI FPV Remote Controller 2 are also smaller in size. [5]
1. Using DJI Goggles 2 and tested in an outdoor open environment without interference.
2. The 155° FOV is only available when using the 4:3 aspect ratio, and when the video recording specification is at 2.7K@50/60fps or 1080p@50fps/60fps; the aspect ratio is 16:9, and the video recording specification is at 4K@50/60fps, 2.7K@50/60fps, or 1080p@50/60fps.
3. 4K/60fps videos do not support the aspect ratio of 4:3, and only support that of 16:9.
4. Sold separately.
5. Compared with DJI FPV Goggles V2 and DJI FPV Remote Controller.
DJI O3 Air Unit Camera Module × 1
DJI O3 Air Unit Transmission Module × 1
DJI O3 Air Unit Antenna × 1
DJI O3 Air Unit 3-in-1 Cable × 1
DJI Goggles 3
DJI FPV Remote Controller 3
DJI Goggles 2
DJI Goggles Integra
DJI FPV Goggles V2
