DJI OM 5
Designed for low-light shooting, DJI OM Fill Light Phone Clamp features a magnetic design for convenient mounting. The built-in LED auxiliary lights provide three brightness levels and three color temperature options, letting you highlight subjects with excellent lighting wherever you go.
Highlights
Built-in LED auxiliary lights with three brightness levels and three color temperature options let you highlight subjects with excellent lighting wherever you go.
Tips
1. Designed with a closed magnetic circuit, the DJI OM Fill Light Phone Clamp will not affect the performance of the phone attached to it. However, some phones may require calibration after mounting due to the angle of the compass. Follow the instructions on the phone to calibrate and use normally.
2. The magnetic design may influence other magnetic products. Do not put the phone clamp near a bank card, cardiac pacemaker, hard drive, or similar devices.
3. Additionally, some phone functions require using magnetic signals to transmit data. In this case, we suggest you remove the phone clamp before using the function.
DJI OM Fill Light Phone Clamp × 1
Dimensions: Folded: 74.13×53×26.55 mm;
Unfolded: 105.91×53×26.55 mm
Weight: 73 g
Illuminance: 20-40 lux @0.6m *
Color Temperature: 5000 ± 200 K (Cold), 3500 ± 200 K (Neutral), 2700 ± 200 K (Warm) *
Power Consumption: 0.38W (Min. Luminance); 0.79W (Max. Luminance)
Battery Life: 3 hr (Min. Luminance); 1.5 hr (Max. Luminance)
Charging Port: Type-C
Charging Time: 35 mins
Charging Temperature: 5° to 40°C (41° to 104°F)
Operating Temperature: 0° to 40°C (32° to 104°F)
*Tested in a controlled environment.
Osmo Mobile 7P
Osmo Mobile 7
Osmo Mobile 6
Osmo Mobile SE
DJI OM 5
DJI OM 4 SE
DJI OM 4
