DJI Mavic 3
  • Incredible Signal Range and Quality
    The upgraded O3+ system supports a video transmission range of up to 15 km [1] with a latency as low as 120 ms.
  • High-Bright Screen
    High-Bright Screen
    DJI RC Pro's 5.5-inch 1080p screen with a brightness of up to 1000 nits is perfect for the Enhanced Display mode.[2] Shadow details are enhanced for a clear display, even under direct sunlight.
  • Updated Processor for Upgraded Performance
    DJI RC Pro is equipped with the latest-generation processor to bring a more durable, stable, and smooth system that simply enhances flying.
  • Fine-Tuned Control
    Fine-Tuned Control
    DJI RC Pro uses the same control stick design as DJI FPV for precise maneuvering, fluid operation, and better shot composition.
  • Outstanding Audio and Video Functions
    DJI RC Pro supports videos played at 4K/120fps in H.264 and H.265 codecs. The system supports the installation of third-party apps [3] for more diversified editing and sharing options.
  • DJI RC Pro
    DJI RC Pro
  • USB 3.0 Type-C Cable
  • Compared with the DJI Smart Controller, what major upgrades does DJI RC Pro have?
  • What are the differences between the ultra-bright display of DJI RC Pro and a normal display?
  • Does DJI RC Pro support quick charging?
  • What is the operating time of DJI RC Pro?
  • Does DJI RC Pro have a speaker and microphone?
*Tested with a DJI Mavic 3 production model in a closed environment in favorable conditions and with an unobstructed wireless signal. Actual results may vary depending on the environment, usage, and firmware version.
**All videos and photos on this page were taken in strict compliance with local laws and regulations.
1. Unobstructed, free of interference, and when FCC-compliant. Maximum flight range specification is a proxy for radio link strength and resilience. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted.
2. The Enhanced Display mode is formerly ‘Outdoor mode.’
3.DJI is not responsible for permissions or information security related to third party apps, and does not provide any technical support for compatibility issues with third party applications. If an installed third-party app prevents you from enjoying optimal use of your controller, we suggest you remove the app or restore the controller to the original factory settings.
