DJI RS 4
  • 2nd-Gen Native Vertical Shooting
    The newly designed gimbal horizontal plate eliminates the need for additional accessories. Easily switch to vertical shooting [1] for efficient vertical video creation.
  • Joystick Mode Switch for Zoom/Gimbal Control
    Cinematographers can easily toggle between joystick modes, allowing them to control either the gimbal movement or the lens zoom via the joystick for a native zoom experience. [2]
  • RSA Communication Port for Extensive Control Ecosystem
    DJI RS 4 introduces an RSA communication port, which allows for the connection of accessories such as the DJI RS Tethered Control Handle and third-party accessories. [3]
  • High-Capacity Battery Grip for Approx. 2.5x Battery Runtime [4]
    The new BG70 High-Capacity Battery Grip [3] can extend RS 4's battery runtime to 29.5 hours. [5] It also supports powering camera and accessories with up to 18 W via the USB-C port.
  • Teflon™-Coated Axis Arms for Smoother Balancing
    Reduced friction aids in smoother balancing and a fine-tuning knob on the tilt axis moves the camera forward and backward for precise, millimeter-level balancing.
  • 3kg (6.6lbs) Payload Capacity With Extended Tilt Axis
    In addition to a high-payload capacity, the tilt axis has been extended by 8.5 mm, allowing for mainstream mirrorless camera and lens combinations, and additional accessories.
  • Gimbal
    Gimbal
  • BG21 Battery Grip
    BG21 Battery Grip
  • Quick-Release Plate (Arca-Swiss/Manfrotto)
  • Extended Grip/Tripod (Plastic)
  • Lens-Fastening Support
  • Multi-Camera Control Cable (USB-C, 30 cm)
  • Screw Kit
    Screw Kit
  • DJI Logo Sticker
    DJI Logo Sticker
Camera Compatibility List
  • What improvements does DJI RS 4 have compared with DJI RS 3?
  • What are the differences between the DJI RS 4 standalone version and the DJI RS 4 Combo? What other DJI RS 4 accessories are worth buying?
  • Is DJI RS 4 compatible with accessories from previous generations?
  • Which cameras and lenses are supported by DJI RS 4?
  • How long is the runtime of the DJI RS 4 battery grip?
  • How long does it take to fully charge the DJI RS 4 battery grip?
  • Are the battery grips of DJI RS 4, DJI RS 4 Pro, and DJI RS 3 interchangeable?
  • Can I use the DJI RS BG70 High-Capacity Battery Grip to charge my camera?
1. The gimbal requires rebalancing after switching between horizontal and vertical shooting.
2. For more details on camera and lens compatibility, please refer to the Ronin Series Compatibility Search page.
3. Sold separately.
4. Data was measured by comparing the battery runtime of DJI RS 4 equipped with the DJI RS BG70 High-Capacity Battery Grip and that of DJI RS 4 equipped with the DJI RS BG21 Battery Grip. Battery runtime was measured in a 25° C (77° F) indoor environment with the gimbal balanced in a level and stationary state until the battery level reached 3% (with the battery grip only powering the gimbal).
5. Measured in a 25° C (77° F) indoor environment with the gimbal balanced in a level and stationary state until the battery level reached 3% (with the battery grip only powering the gimbal).
6. The DJI RS 4 Combo includes a DJI Focus Pro Motor. For the standalone version, the motor is sold separately.
