DJI RS 4 Pro
  • 2nd-Gen Native Vertical Shooting
    The newly designed gimbal horizontal plate eliminates the need for additional accessories. Cinematographers can easily switch to vertical shooting. [1]
  • Approx. 2.4x Battery Runtime, All-Scenario Solutions
    Extend runtime up to 29 hours [2] with the RS BG70 High-Capacity Battery Grip.[3] And choose from various handheld configurations with RS SDK protocol. [4]
  • Supports Dual Focus & Zoom Motors With Remote Control
    Get precision focus and zoom simultaneously by installing two Focus Pro Motors. [5] Pair with the Focus Pro Hand Unit and High-Bright Remote Monitor [2] and get refined remote gimbal and focus control.
  • LiDAR Focusing: 76,800 Ranging Points Within 20 m [6]
    Solo cinematographers can now experience more accurate, distant, and intelligent LiDAR autofocus. [7] The next-gen ActiveTrack Pro can firmly lock on to a moving subject.
  • LiDAR & Transmission Interconnectivity
    With the Focus Pro LiDAR to DJI Transmission Cable Hub, [2] RS 4 Pro can power LiDAR and the DJI Video Transmitter simultaneously, [2] achieve LiDAR Waveform, [8] and convenient control.
  • 4.5kg (10lbs) Payload Capacity With a 20% Increase in Motor Torque [9]
    The carbon fiber axis arms are capable of accommodating mainstream mirrorless/cinema camera and lens setups. The gimbal provides greater power redundancy once balanced.
  • Gimbal
    Gimbal
  • BG30 Battery Grip
    BG30 Battery Grip
  • Quick-Release Plate (Arca-Swiss/Manfrotto)
  • Extended Grip/Tripod (Metal)
  • Briefcase Handle
    Briefcase Handle
  • Lens-Fastening Support (Extended)
  • Multi-Camera Control Cable (USB-C, 30 cm)
  • Screw Kit
    Screw Kit
  • Carrying Case
    Carrying Case
  • DJI Logo Sticker
    DJI Logo Sticker
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
Lightweight Travel Camera Stabilizer
Expansive Flagship Stabilizer
From USD $369
From USD $237
From USD $469
From USD $869
890 g (2 lbs)Gimbal Weight
795 gWeight
1.4 kg (3.1 lbs)Gimbal Weight
1.6 kg (3.5 lbs)Gimbal Weight
2 kg (4.4 lbs)Max Payload
3 kg (6.6 lbs)Max Payload
4.5 kg (10 lbs)Max Payload
2nd-Gen AutomatedAxis Locks
Manual Axis LocksAxis Locks
2nd-Gen Automated Axis LocksAxis Locks
Aluminum AlloyAxis Arm Material
Carbon FiberAxis Arm Material
YesFine-Tuning Knob
YesFine-Tuning Knob
YesFine-Tuning Knob
img1.4″ LCD Full-Color
img1.4″ LCD Full-Color Touchscreen
img1.8″ OLED Full-Color Touchscreen
img4th-Gen Stabilization Algorithm
img3rd-Gen RS Stabilization Algorithm
img4th-Gen RS Stabilization Algorithm
Zoom/Gimbal ControlJoystick Mode
img3rd-Gen Native Vertical Shooting
imgNative Vertical Shooting (Horizontal Arm Detachment Required)
img2nd-Gen Native Vertical Shooting
Non-DetachableBattery Design
UndetachableBattery Design
13 Hours‌Max Battery Runtime
10 Hours‌Max Battery Runtime
29.5 Hours‌Max Battery Runtime
29 Hours‌Max Battery Runtime
imgNATO Port × 1
imgNATO Port × 1
imgRSA Port × 1;
NATO Port × 2;
Charging Adapter Port × 1
imgRSA Port × 2;
NATO Port × 2;
imgSupports Bluetooth zoom control, Bluetooth shutter and wired shutter
imgSupports Bluetooth shutter and wired shutter
imgSupports external focus motor control, Bluetooth zoom control, Bluetooth shutter, and wired shutter
imgSupports dual external focus motor control, Bluetooth zoom control, Bluetooth shutter, and wired shutter
imgDJI PRO Ecosystem
Camera Compatibility List
1. The gimbal requires rebalancing after switching between horizontal and vertical shooting.
2. Sold separately.
3. Measured in a 25° C (77° F) indoor environment with the gimbal balanced in a level and stationary state until the battery level reached 3% (with the battery grip only powering the gimbal).
4. Setting up any of the shooting solutions requires one or more accessories that are sold separately.
5. The DJI RS 4 Pro Combo includes a DJI Focus Pro Motor. For the standalone version, the motor is sold separately.
6. Requires enabling the 2x zoom display function on the DJI RS 4 Pro touchscreen.
7. Requires the DJI Focus Pro Motor.
8. LiDAR Waveform is only available when DJI RS 4 Pro is paired with a DJI Focus Pro Motor.
9. Compared with DJI RS 3 Pro.
10. For more details on camera and lens compatibility, please refer to the Ronin Series Compatibility Search page.
