Osmo Action 4
  • 1/1.3-inch Image Sensor
  • 10-bit & D-Log M Peformance
  • Packed with Peformance
  • 360° HorizonSteady
    360° HorizonSteady
  • Extensive Accessories
  • DJI OsmoAudio™
    DJI OsmoAudio™
  • Osmo Action 4
    Osmo Action 4
  • Osmo Action Extreme Battery
  • Osmo Action Road Cycling Accessory Kit
  • Osmo Locking Screw
    Osmo Locking Screw
  • Type-C to Type-C PD Cable
  • Osmo Action Lens Hood
  • Osmo Action Anti-Slip Pad
Moments By You
    With a sturdy build, Osmo Action 4 is waterproof up to 18 meters without a case and supports operation with wet hands. Combine it with practical accessories like the Diving Accessory Kit, DJI Floating Handle, or the Surfing Tether, and freely explore the underwater world, capturing your aquatic adventures.
    No matter how bumpy the ride, 360º HorizonSteady and RockSteady 3.0 ensure smooth footage. With the Biking Accessory Kit, Road Cycling Accessory Kits, Handlebar Mount, or the Osmo Action Mounting Kit, you can easily and securely capture your adventures on road bikes, mountain bikes, and motorcycles.
    Enable Pre-Rec in advance to ensure you capture the action as it happens. Once you press the shutter button, the camera will save the footage of the preset time frame that has just passed so that you can record the entire process – perfect for fishing trips. Never miss the best moment; no more worries about storing lengthy recordings.
    Boasting robust cold-resistance capabilities, Osmo Action 4 can continuously record 150 minutes in temperatures as low as -20° C (-4° F). Use it with a 1.5m Extension Rod or Mini Extension Rod to eliminate the visible selfie stick in your shots, creating the vibe of having a follow-cam photographer with you in every shot. Don't let icy weather chill your creative passion.
  • What improvements does Osmo Action 4 have in terms of image quality? What are its advantages in low-light recording?
  • What is D-Log M of Osmo Action 4's color mode?
  • What resolution settings does Osmo Action 4 support?
  • What video and stabilization specifications does auto low-light image enhancement support?
  • What additional accessories are included in the Adventure Combo compared to the Standard Combo? Is it worth buying?
  • Is Osmo Action 4 compatible with accessories of the last-generation product?
  • Can I mount third-party action camera accessories to Osmo Action 4?
  • What is RockSteady 3.0?
  • What is HorizonSteady?
  • Does Osmo Action 4 support fast charging?
  • What microSD cards does Osmo Action 4 support?
  • Does Osmo Action 4 support the Osmo Action Extreme Battery Plus (1950 mAh)?
5. Sold separately.
