DJI Air 3S Intelligent Flight Battery
Provides Air 3S with up to 45 minutes of flight time*, allowing you to explore, compose, and get the shots you want, all during a single flight.
It also brings the Off-State QuickTransfer** feature to Air 3S, enabling high-speed file transfer directly to your smartphone, even when the drone is powered off.
Intelligent Flight Battery × 1
Model: BWX234-4276-14.6
Capacity: 4276 mAh
Battery Type: Li-ion 4S
Charging Temperature: 5° to 40° C (41° to 104° F)
DJI Air 3S
DJI Air 3
* Measured by DJI Air 3S flying forward at a constant speed of 32.4 kph in a windless environment at sea level, with Obstacle Avoidance Action set to Brake, in photo mode, and from 100% battery level until 0%. Data is for reference only. Always pay attention to reminders in the app during your flight.
** After powering off, the drone enters sleep mode for up to 12 hours, during which the Off-State QuickTransfer feature is available. Battery drain is approximately 2% over 6 hours in sleep mode. Sleep mode will automatically deactivate after 12 hours and can be reactivated by a short press of the power button.
