DJI Mavic 3 Cine Premium Combo
Select Option
A Camera for Capturing the Best
The 4/3 CMOS Hasselblad camera can effectively suppress noise in low-light environments, delivering higher resolution and dynamic range.
Tele Camera For Unique Shots
The tele camera can be used to frame shots or explore. Whether capturing landscapes or people, enjoy more flexibility and creative potential.
Extended Flight Time to See More
Up to 46 minutes of flight time [1] lets you plan flight routes, compose your shots, and capture it all with ease.
Upgraded Transmission System
The upgraded O3+ transmission system enables a 15km* max transmission range and a 1080p/60fps [2] live feed for smooth, stable flights.
Fly with Intelligent Safety
With omnidirectional obstacle sensing, Mavic 3 can detect obstacles in all directions and plan a safe flight route. [3]
A Pro Codec for Pro Creation
Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT [4] encoding and has a built-in 1TB SSD, [5] facilitating professional creation in every way.
DJI Mavic 3 Cine
DJI RC Pro
Spare DJI RC Pro Control Sticks (pair)
DJI Mavic 3 Intelligent Flight Battery
× 3
DJI Mavic 3 Low-Noise Propellers (pair)
× 6
DJI 65W Portable Charger
DJI Mavic 3 Storage Cover
USB-C Cable
DJI Mavic 3 Battery Charging Hub
DJI Convertible Carrying Bag
DJI Mavic 3 ND Filters Set (ND4/8/16/32)
DJI Mavic 3 ND Filters Set (ND64/128/256/512)
DJI 10Gbps Lightspeed Data Cable
Moments by You
From USD $2,049
From USD $1,279
From USD $4,999
Tele Camera: 4K/50fps
DCI 4K/120fps
DCI 4K/120fps
Apple ProRes 422 HQ/422/422 LT
1080p/60fps Transmission
Compared to DJI Mavic 2, what major upgrades does Mavic 3 have?
DJI Mavic 3 is DJI's next-generation flagship consumer camera drone. Compared to Mavic 2, major upgrades include:
- Mavic 3 offers significantly improved imaging performance thanks to its 4/3 CMOS Hasselblad camera and 24mm-equivalent lightweight lens. It can record up to 5.1K/50fps or 4K/120fps videos.
- Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT encoding, offering better image quality and greater flexibility during post-processing.
- The flight experience has also been comprehensively improved with the flight time extended to 46 minutes. And thanks to incredibly stable O3+ technology, video transmission can reach up to 15 km.
- DJI Mavic 3 is equipped with an omnidirectional obstacle sensing system and supports the upgraded APAS 5.0 and Advanced RTH, letting creators enjoy safe flight with peace of mind.
What's the difference between the combos?
Compared with the standard Mavic 3 combo, DJI Mavic 3 Fly More Combo includes two additional Intelligent Flight Batteries, one Battery Charging Hub, one Convertible Carrying Bag, and one ND Filters Set (ND4/8/16/32) to help you explore and shoot in more scenarios.
Compared with the DJI Mavic 3 Fly More Combo, the DJI Mavic 3 Cine Premium Combo includes a Mavic 3 Cine aircraft that supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT video encoding and has a built-in 1TB SSD, an upgraded DJI RC Pro with a high-bright display, one ND Filters Set (ND64/128/256/512), a 10Gbps Lightspeed cable, and other accessories that help facilitate professional-level imaging.
Is Mavic 3 compatible with the accessories of the Mavic 2 series?
No.
What are the advantages of Mavic 3's imaging system?
Mavic 3 is equipped with a dual-camera system. First, the Hasselblad camera has a professional-level 4/3 CMOS sensor and supports the Hasselblad Natural Colour Solution, allowing users to get stunning results without the need for post-processing. Mavic 3 Cine goes one step further, offering support for Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT encoding. Second, the tele lens of the dual-camera system supports Explore mode for 28x hybrid zoom, allowing you to see more of your environment and plan shots with ease.
How does the omnidirectional obstacle sensing work?
Multiple wide-angle vision sensors onboard work together seamlessly with a high-performance vision computing engine to sense obstacles in all directions precisely and plan a safe flight route that avoids obstacles.
Compared with O3, what improvements does O3+ have?
The O3+ transmission system has a transmission range of up to 15 km and supports 1080p/60fps real-time transmission.
Note: Unobstructed, free of interference, and when FCC-compliant. Maximum flight range specification is a proxy for radio link strength and resilience. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted.
[1] Measured with Mavic 3 flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery reached 0%. Data is for reference only. Please pay attention to the RTH reminder on the DJI Fly app during flight.
[2] Unobstructed and free of interference. Actual resolution may vary depending on the quality of the transmission signal.
[3] DO NOT use the aircraft in severe weather conditions including heavy wind exceeding 13.8 m/s, snow, rain, fog, hail, or lightning. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may be limited. When the GNSS signal is weak, fly the aircraft in environments with good lighting and visibility. Low ambient light may cause the vision system to function abnormally. DO NOT fly near areas with magnetic or radio interference. Common sources of magnetic or radio interference include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Be careful when taking off in desert or beach areas to avoid sand entering the aircraft. Fly the aircraft in open areas. Buildings, mountains, and trees may block the GNSS signal and affect the on-board compass.
[4] DJI Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, Apple ProRes 422 LT and H.264/H.265 encoding, while Mavic 3 only supports H.264/H.265 encoding.
[5] Actual available storage space may be reduced due to system configuration. For more details, see the Mavic 3 specs.
[6] ActiveTrack is not available at video resolutions higher than 4K or frame rates over 60fps.
