DJI Mic 2 Transmitter (Pearl White)
Select Option
Sound Great With the DJI Mic 2
Capture brilliant audio with the DJI Mic 2's omnidirectional recording. This wireless microphone is optimized for vocals, making handling vlogs, interviews, and more a breeze.
When Quietness Matters
The new intelligent noise cancelling feature [1] effectively reduces environmental noise for clean and clear conversations, even in noisy areas.
Extended Battery Life
Each transmitter and receiver has a remarkable 6-hour operating time, [2] which can be extended to a generous 18 hours with the charging case.
250m (820 ft.) Range
With powerful anti-interference capability, wireless microphone Mic 2 offers a 250m (820 ft.) max audio transmission range, [3] meeting the needs of most scenarios.
All-In-One Storage
The charging case automatically pairs the receiver and transmitters, so you can get started as soon as you open it up.
Versatile and Impressive
Each transmitter has 8 GB of internal storage for up to 14 hours of uncompressed 48kHz 24-bit audio and 32-bit float internal recording. [4]
Extensive Compatibility
Mic 2 supports USB-C and Lightning outputs, as well as 3.5mm TRS analog output. It is compatible with most cameras, smartphones, and computers.
DJI OsmoAudio™
The transmitter supports direct connection to select DJI products [5] without a receiver, delivering premium audio and simplifying your gear and workflow. The transmitters can also connect directly to smartphones via Bluetooth and work with third-party video recording apps [6].
DJI Mic 2 Windscreen (White)
DJI Mic 2 Clip Magnet
DJI Mic 2 Carrying Pouch
DJI Mic USB-C Charging Cable
From USD $129
From USD $159
1.1-inch touchscreen + dial
0.95-inch touchscreen
Noise Cancelling
8 GB, 24-bit/32-bit float
14-hour internal recordingReceiver: 6 hours
Charging Case: 18 hours
What can I use DJI Mic 2 with?
What devices can the DJI Mic 2 Transmitter connect to wirelessly? How many transmitters can be connected at the same time?
What are the differences between different DJI Mic 2 combos? How should I choose?
Do I need to activate DJI Mic 2?
What functions does the DJI Mic 2 Charging Case provide?
How long does it take to fully charge the transmitters and receiver using the DJI Mic 2 Charging Case? How long does it take to fully charge the charging case?
What is the internal storage of the DJI Mic 2 transmitters? Do the transmitters support external SD cards for storage?
1. Intelligent noise cancelling of DJI Mic 2 cannot be enabled when the transmitter is connected to a smartphone via Bluetooth.
2. Tested with both transmitters connected to the receiver, without backup recording, and the receiver connected to a camera with the Camera Audio Cable (3.5mm TRS).
3. Measured with FCC compliance in an unobstructed environment without interference (160 m under CE). Actual transmission distance may vary depending on environment.
4. Internal recording of DJI Mic 2 cannot be used when the transmitter is connected to a smartphone via Bluetooth.
5. DJI Mic 2 transmitters can directly connect to select DJI products (one TX for Osmo Action 4, up to two TX for Osmo Pocket 3, Osmo Action 5 Pro, and other compatible DJI products). Additional DJI products will be supported in the future.
