Osmo Action 5 Pro Neck Mount Filming Combo
Select Option
Powerful All-New 1/1.3″ Sensor
Subject Tracking, Stay Centered
4hrs Extended Battery Life
Dual OLED High-Brightness Touchscreens
Robust Stabilization
DJI Microphone Connection
Versatile Accessory Ecosystem
Osmo Action 5 Pro
Osmo Locking Screw
Type-C to Type-C PD Cable
Osmo Action 5 Pro Rubber Lens Protector
Osmo Action 5 Pro Glass Lens Cover
Osmo Action Anti-Slip Pad
Moments By You
From USD $319
From USD $239
1/1.3″ CMOS
1/1.3″ CMOS
High Dynamic Range for All Video Specifications 4K/60fps High-Dynamic Low-Light Imaging
LCD & No HDR DisplayLet’s Answer Your Questions
What improvements does Osmo Action 5 Pro offer compared with the previous generation?
What additional accessories are included in the Adventure Combo compared with the Standard Combo? Is it worth buying?
Is Osmo Action 5 Pro compatible with accessories from the previous generation?
Can I mount third-party action camera accessories to Osmo Action 5 Pro?
What resolution settings does Osmo Action 5 Pro support?
What is RockSteady 3.0?
What is HorizonSteady?
What video and stabilization specifications does SuperNight mode support? When should I use this mode?
Can Osmo Action 5 Pro be used while charging?
What microSD cards does Osmo Action 5 Pro support?
5. Sold separately.
