Osmo Action 5 Pro
  • 4hrs Extended Battery Life
  • Robust Stabilization
  • DJI Microphone Connection
  • Osmo Action 5 Pro
    Osmo Action 5 Pro
  • Osmo Action Surfing Tether Kit
  • Osmo Locking Screw
    Osmo Locking Screw
  • Type-C to Type-C PD Cable
  • Osmo Action Anti-Slip Pad
Moments By You
    Simply power on with one button and dive up to 20 meters deep unhindered by additional accessories. The built-in color temperature sensor ensures true-to-life colors. Pair it with the Mimo app's Vivid Underwater feature for more natural underwater footage. With the built-in pressure gauge, the camera automatically starts or stops recording upon entering or exiting the water.
    HorizonSteady not only effectively reduces shakes but also corrects horizontal tilts within a 360° range, handling intense bumps and rotations effortlessly. RockSteady 3.0 effectively reduces shakes while retaining the dynamic impact of motion, delivering a more immersive first-person perspective. Even at high altitudes, the camera captures stable, engaging footage.
    Action 5 Pro can be mounted flexibly to capture the excitement of your ride from different angles. Featuring three built-in microphones, Action 5 Pro captures immersive stereo sound. It also supports switching between Mono and Stereo modes, delivering high-impact audio.
    Action 5 Pro can analyze 240fps video frame by frame, intelligently achieving up to 32x Super Slow Motion with frame interpolation. With the InvisiStick feature and Subject Tracking mode, you can effortlessly produce clean footage where the subject remains centered. The camera keeps rolling even in temperatures as low as -20° C, for up to 3.6 hours.
Osmo Action 5 Pro
Osmo Action 4
Osmo Action 4 Standard Combo
Osmo Action 5 Pro
Osmo Action 4
From USD $319
From USD $239
Imaging Performance
1/1.3″ CMOS
1/1.3″ CMOS
High Dynamic Range for All Video Specifications
1080p/240fpsSlow Motion
Stabilization
RockSteady 3.0/3.0+
RockSteady 3.0/3.0+
Main Body
240 minsMax Operating Time
160 minsMax Operating Time
LCD & No HDR Display
20 mCaseless Waterproof
18 mCaseless Waterproof
YesBuilt-in Pressure Gauge
47 GBBuilt-in Storage
  • What improvements does Osmo Action 5 Pro offer compared with the previous generation?
  • What additional accessories are included in the Adventure Combo compared with the Standard Combo? Is it worth buying?
  • Is Osmo Action 5 Pro compatible with accessories from the previous generation?
  • Can I mount third-party action camera accessories to Osmo Action 5 Pro?
  • What resolution settings does Osmo Action 5 Pro support?
  • What is RockSteady 3.0?
  • What is HorizonSteady?
  • What video and stabilization specifications does SuperNight mode support? When should I use this mode?
  • Can Osmo Action 5 Pro be used while charging?
  • What microSD cards does Osmo Action 5 Pro support?
5. Sold separately.
