DJI Ronin 4D
  • Full-frame 8K/60fps & 4K/120fps
    Zenmuse X9 supports internal recording of Apple ProRes RAW, ProRes 4444 XQ, ProRes 422 HQ, ProRes 422 LT, and H.264 video, [1] and up to 8K/60fps and 4K/120fps full-frame video recording. It also supports the ACES workflow.
  • Dual-native ISO 800/4000 [2]
    X9-8K defaults to EI 320/1600. With Dynamic Range Expansion on, X9-8K can support EI 800/4000, while X9-6K supports EI 800/5000, allowing it to capture footage with exquisite detail and minimal noise.
  • Built-In 9-Stop Physical ND Filters
    X9 has 9-stop built-in physical ND filters (ND 2 to ND 512, or ND 0.3 to ND 2.7) that can be quickly and easily switched thanks to a motorized internal system.
  • DL/E/L/PL/M Interchangeable Lens Mount
    X9 supports DJI's proprietary DL mount, as well as Leica L, Leica M, Sony E, ARRI PL, and more. [3] Lenses compatible with these mounts can also be used with X9. [4]
  • Autofocus on Manual Lenses
    With the LiDAR focusing system and focus motor, autofocus is available even on manual lenses. [4] In Automated Manual Focus mode, [5] the focus wheel will rotate in sync as the focus point changes, but cinematographers can take manual control at any point.
  • 4-Axis Active Stabilization on Par with a Dolly
    The Z-Axis effectively eliminates vertical camera shake and works with visual sensors and ActiveTrack Pro to let you create smooth, stable footage effortlessly.
  • Up to 20,000-foot Wireless Transmission and Control Range [6]
    O3 Pro Video Transmission Technology adds DFS frequency bands and enables 1080p/60fps video transmission. It supports one transmitter with multiple receivers and can remotely control gimbal, focusing, and camera settings.
  • Zenmuse X9-6K Gimbal Camera
  • Main Body
    Main Body
  • LiDAR Range Finder
    LiDAR Range Finder
  • DL Mount
    DL Mount
  • Left Hand Grip
    Left Hand Grip
  • Right Hand Grip
    Right Hand Grip
  • Top Handle
    Top Handle
  • High-Bright Main Monitor
  • TB50 Battery Mount
    TB50 Battery Mount
  • Power Adapter
    Power Adapter
  • TB50 Charging Adapter
  • AC Power Cable
    AC Power Cable
    × 8
  • USB-A to USB-C Cable
  • Base Plate
    Base Plate
  • Hand Grip Extended Control Sticks
  • 3mm Ball-End Hex Key
  • 2.5mm Ball-End Hex Key
  • 1.5mm Ball-End Hex Key
  • 10mm 1/4"-20 Screw
    10mm 1/4"-20 Screw
    × 3
  • Flat Head Screwdriver
  • X9 Gimbal Base Cap
    X9 Gimbal Base Cap
  • DX Mount Body Cap
    DX Mount Body Cap
  • DX Mount Lens Cap
    DX Mount Lens Cap
  • Ronin 4D Gimbal Base Cap
  • TB50 Intelligent Battery
  • LiDAR Range Finder/Focus Motor Cable
  • Left Hand Grip Strap
  • Right Hand Grip Strap
  • Ronin 4D Carrying Case
  • X9 Counterweight (106 g)
DJI Ronin 4D-8K
DJI Ronin 4D-6K
DJI Ronin 4D-8K
DJI Ronin 4D-6K
DJI Ronin 4D-8K
DJI Ronin 4D-6K
From USD $9,999
From USD $4,999
imgFractional Frame Rates
4K/120fps (Full-frame 17:9)Highest Frame Rate
4K/120fps (S35 2.39:1)Highest Frame Rate
imgRecording Codec
Apple ProRes RAW
Apple ProRes 422 HQ
H.264
imgRecording Codec
Apple ProRes RAW
Apple ProRes 4444 XQ
Apple ProRes 422 HQ
Apple ProRes 422 LT
H.264
imgNative ISO
320/1600 (Default)
800/4000 (Dynamic Range Expansion on*)
imgNative ISO
800/5000
14.7 stopsHighest Dynamic Range
14.3 StopsHighest Dynamic Range
1. Ronin 4D-8K only supports recording of Apple ProRes RAW, ProRes 422 HQ, and H.264 video.
2. Requires enabling the Dynamic Range Expansion mode (in full-frame format, with sensor frame rate ≤30fps).
3. E-mount and PL-mount units are provided by third parties.
4. X9 has certain limitations on lens size, weight, and structure. Please check the DJI Ronin 4D Lens Compatibility List for more information.
5. Requires Hand Grips.
6. Measured with video transmission and control system operating in Control mode in an unobstructed environment free of interference with FCC compliance.
